-   -   hurst quarter stick (https://www.racingjunk.com/forums/showthread.php?t=20761)
john910 05-08-2008 08:44 AM
hurst quarter stick
i bought a used shifter here on racing junk. was told it was used on turbo 350. when i got it it must be for power glide. does anyone one know where or who to contact to get parts to convert to 3 speed. went to b&m web site no help. when i shift from first it got right to third . thanks, john
fla1976 05-08-2008 12:35 PM
Quarter stick
You should be able to physically check the shifter to see if it is for a PG or a 350. It may be a 350 but is for a reverse pattern valve body.
curtisreed 05-08-2008 01:03 PM
I have bought the shift plates from Jegs before to make a three speed shifter to a pg shifter, very simple. Should be able to do the same thing the other way.
Curtis
johnson73801 05-31-2008 03:32 AM
do you have the cable adjusted correctly? if so how many clicks do u hear from the shifter when you go from park to first?
john858 06-01-2008 05:50 AM
i don't think you can change a b&m from a glide to a turbo it's hurst you can do that with. it might be the other way around but i think i'm right. good luck.
curtisreed 06-01-2008 07:50 AM
The topic title says HURST.
john858 06-01-2008 01:14 PM
yes but in the thread it said (went to b&m web site)
curtisreed 06-01-2008 04:09 PM
I think one bought the other I just don't know which way it is.
Curtis
john858 06-02-2008 10:19 AM
well hopefully they make them all changable,but of coarse that would make it to easy for us racers
john
