-   -   Timing on 620" BBC (https://www.racingjunk.com/forums/showthread.php?t=20698)
lmchevy 05-02-2008 05:13 PM
Timing on 620" BBC
Where would you run your timing on a 14.8-1 620" BBC and be safe.It is carburated on gas and n/a.Thanks
topcat572 05-02-2008 05:25 PM
timing
I ll get the ball rolling for the other guys to chime in, What head are You running, I hear the ones with the smaller chambers use less timing,Anyone? I run 37 now on a 572 conventional head.
lmchevy 05-02-2008 06:03 PM
head
I have the Pro1 355 cnc heads.119cc chambers.
bjuice 05-02-2008 06:14 PM
i have a 632 with 14 degree big chief heads on gas...it likes 34.
as they say start off conservative and work up...i will go out on a limb and say 32 would be a ( extra) safe place to start and go from there if it were mine and no dyno records to show sweet spot with timing
Brian
hammertime 05-02-2008 07:16 PM
I used to put my gas motors around 39-40, on the dyno last year my motor shop at the time started at 32. I sat back and just watched sure enough it made more hp at 34 then at 39. Every motor is different
LuckyDawgRacing 05-03-2008 07:51 AM
I'm at 36 on alky
tcarda 05-03-2008 02:28 PM
Re: Timing on 620" BBC
My engine that has 355 heads on it likes 38. Is there a engine dyno you can take it to and find out what it likes?
lmchevy 05-03-2008 03:17 PM
timing
Tcarda i probably could go and put it on a chassis dyno.
bjuice 05-03-2008 03:20 PM
Re: timing
chassis dyno probably would not tell you what your looking for since there is no telling how much HP is being lost thru the chassis.
my advise is save your time and money on the chassis dyno for this purpose.
Brian
Tod74 05-03-2008 06:36 PM
Re: timing
Brian
That's a good point but I have a question.
Wouldn't the chasis dyno still allow you to see a gain or a loss from a timing adjustment? I mean, regardless of what it is making at the crankshaft, if it is showing say 500 hp 400 ft lbs on the chasis dyno, and you advance the timing 1 or two degrees, then run it again, take a reading,then retard it and run it again..take another reading...wouldn't this allow you to find the timing that makes the most power?
Regardless if the hp numbers are bogus...as long as they are consistantly bogus...wouldn't that allow you to find the tune up?
Not arguing here...just asking.
