-   -   rollout?? (https://www.racingjunk.com/forums/showthread.php?t=20676)
kw89425 04-29-2008 05:17 PM
rollout??
i got my new slicks today from jegs one has 97" and the other has 98" rollout. will this give me problems?
bjuice 04-29-2008 05:25 PM
it could give you problems by pulling to one side....
you can make up some of the difference by taking the 97 roll out tire and putting the air to it and letting it sit for a while..you are actually stretching the tire..it will work..
brian
kw89425 04-29-2008 05:29 PM
ill give it a try its going to be another couple weeks befor i get the car ready. thanks
gearhead1011 04-29-2008 08:16 PM
Put an extra 10-15 lbs in it and leave it for a couple of hours then let it down to the same pressure as the other one and recheck the roll out. I think the most difference you want is 3/4 inch but I usually try to get mine within 1/4. This will only work on new tires, once you run them it doesn't work.
