-   -   327 build up (https://www.racingjunk.com/forums/showthread.php?t=20612)
huffman24 04-23-2008 12:47 PM
327 build up
I'm building a 327 small journal 30 over, its got a stock crank and rods, speed pro forged pistons .125 dome, comp cam, 501/501 lift, 244/244 duration, camel back heads ported and polished, screw in studs and guideplates, 2,02 int, 160 exh, double valve springs, 1.5 roller rockers.
I want ideas about what intake to use and pushrod size. i have a weiand tunnal ram 2by4 set up, but i'm going for street and strip. Any info would help.
thanks
Tod74 04-23-2008 04:55 PM
Re: 327 build up
thanks
I had that same cam in a mild 400...ran good.
huffman24 04-23-2008 04:59 PM
Yea that cam gives good power and it has a nice chop
Tod74 04-23-2008 05:56 PM
I would Use a performer RPM works well with that cam .
nofear57 04-23-2008 07:44 PM
Nice engine. Don't see to many stock cubes any more. Seems like everyone is going big or bigger these days. I commend you on your choose of engine 8) Just keep the RPM's around 6,000 with those rods and she'll live forever!
So whats it going into? Street and strip? Auto w/stall or standard trans.? What size of carb,vaccum or double? Rear gears?
Fill us in Dude :D
huffman24 04-23-2008 08:02 PM
86 s-10, th350 with 2700-3000 stall, 373 gears, and holley 650 double pumper
huffman24 04-24-2008 12:55 PM
Does have a opinin on what I could chage or what can I do to get the max HP out of the motor? I'm new at all this performance and stuff, but I do know you got to have the stuff match up to have it right. Anything would help
jmarksdragster 04-24-2008 01:14 PM
Victor Jr's are easy to find and work well, the tunnel ram will only be grief in your case. 5/16 .080 wall PR will work fine for you. As long as you used stock length valves, stock length PR's will be fine. A 4778 700 or 4779 750 would be a good place to start as well.
huffman24 04-24-2008 01:25 PM
Thank you I do have stock length valves. So the stock PR will work?
nofear57 04-24-2008 06:16 PM
I would put on a RPM Air-Gap intake and with only 327 cubes I would stick with the 650 carb. The tunnel ram would look "Awesome" but you would have to run some small carbs on it like 500cfm or 600cfm vaccums.
A set of smaller AFR alum. heads would really open it up 8) Hey maybe even a 75 or 100hp shot of nitrous for the strip!
