-   -   Can heads be too Big (https://www.racingjunk.com/forums/showthread.php?t=20605)
blaserman 04-22-2008 04:25 PM
This was just an information Question. Some of the Head manufactors
web site quote compression ratios for there heads . Lets say 632 cu
10-1 compression 714-750 cam shaft soild roller. cam 360 head or bigger be too much.
Tod74 04-22-2008 06:30 PM
yes heads can be too big....helmets only come in so many sizes.
hammertime 04-23-2008 03:29 AM
Re: Can heads be too Big
I'd tell you that head is perfect :lol:
Really thought many disagree with me but myself and a few locals keep going back to a huge head on smaller motors and they just down right fly ! I've now did this 2 times 548 with dart 410's and 468 with dart 355's, a good friend of mine put dart 360's on his 496 all 3 motors really ran good better then anything around here with the same size motor and smaller head.
nofear57 04-25-2008 08:51 AM
That being said,the carb and cam have to work together also.
Did you guys have to try different carbs and cams with the low compression,big heads and big cubes to make things work together :?: Was there a fine point(small window) for the carb and cam :?:
olds48 04-25-2008 04:05 PM
:lol: :lol: :lol: Heads are never too big,it's the motor that is under them is just too small :wink:
hammertime 04-25-2008 07:17 PM
we did not stuck a cam/carb that anyone would with the size motors would run
Tod74 04-25-2008 09:36 PM
I like how you think. :D
olds48 04-25-2008 11:11 PM
:D :D :D
