THANKS ED!
[quote="edvancedengines"]With the best quality Ti-17 Professional Grade Retainrs the retainer OD is smaller than the spring OD. There is no reason for the retainer to be as large or larger than the spring.} Thanks Ed-I replaced my Manley Titanium retainers with a set of Xceldyne Titanium retainers that fit snug in the springs and are smaller then the spring OD,chambered the springs,clearanced the rockers to remove the rubbing marks and now the rockers have NO marks on them after several 1/4 mile passes.
http://i144.photobucket.com/albums/r...3/IMG_1493.jpg |
Wheels up and haul'in,nice :D
Ok......now you have our attention........give power details and times on your combo! |
nofear69: My camaro weighs 3100,383,13-1,.558 int,.550 ex,260,[email protected] comp flat tappet,stock 215 Dart Iron Eagle Platinums,Manley 6 inch rods,Super Victor port matched,750 APD Alky Carb,Powerglide Trans-Car ran 6.57@104 at the track in the pic,1/8 MILE
Perfect :D I love the nothing over kill combos.
Small cubes,carb,cam and heads but good compression with alcohol. This should be a bullet proof low maintenace engine,everything works together. You did your home work,cool 8) and the small tires give it that sleeper look. Loose a little weight and the 5's aren't to far away. My hats off to you,great 67' Camaro :D |
Thanks,it's a 68 with a 67 grille.I couldn't find a 68 grille at the time.The car is all steel and the original windows.
Thank you for the acknowledgement. Appreciate it.
Ed |
Your welcome and thank you for the GREAT ADVICE!
I finally ran the camaro at Bakersfield this weekend.BEST E.T. TO DATE.....10.32 AT 130.30 M.P.H.http://i144.photobucket.com/albums/r...3/IMG_1493.jpg
| All times are GMT -8. The time now is 12:08 PM. |
