-   -   oil pump spring (https://www.racingjunk.com/forums/showthread.php?t=20584)
fishman1 04-19-2008 06:46 PM
oil pump spring
Hi guys i did a search but couldn't find anything on this, i am changing my spring in my oil pump to a high pressure one, i noticed that in the pump it only has one hole so makes it kinda tricky to get the pin out, is there any easy way to get this out or a diffrent way instead of cutting it to get it out.
thanks
dcarr511 04-19-2008 07:01 PM
take the cover off then you can remove the pin.
fishman1 04-19-2008 07:20 PM
shit i have the pickup already pressed into the oil pump
sc3314 04-20-2008 03:46 AM
oil pump
Just a good idea to weld the pick up onto the pump. When you change the spring. The Moroso billet pump has adjustable pressure settings for $100.00
JMT
