Which fuel line is better?
I'm setting up my single 1150 Dominator carb and I'm not sure which way to go with the fuel line from the regulator? Should I use a anologue fuel line on the carb from the regulator or 2 seperate lines from the regulator to the carb?
The car is a 8.50 certified 56' chevy with a Reher-Morrison 555ci. 900hp with no power adders. I have a MagnaFuel electric fuel pump(its a QuickStar 300)in the trunk. |
i run a fuel log on my 511ci making over 800 hp with no problems..also flip back and forth from gas to alcohol and back to gas..same plumbing..i run a magnafuel prostar 500 and a magnafuel 2 port regulator.....if it were mine i would go with what you have..the dual line would probably be the cheapest..
just my take. Brian |
I've heard that the Fuel log stores a little extra fuel and that the carb will not run low in certain situations. This is just what I've heard,I don't know if theres any truth to this or not?
i have also heard the same thing. :D
as long as you don't have routing issues, no reason not to use the fuel log as long as it is large enough to supply the necessary fuel.
| All times are GMT -8. The time now is 08:53 AM. |
