Pistons hitting head.
I just bought some new Brodix -2x heads and I went to put them on my motor tonight and they seem to be hitting the head. I put one on last weekend with my old head gaskets to figure out pushrod length. I only put a few bolts in and ran em down snug cause I figured the head gasket was used and would be compressed already.( fp 1017-1) Checked P V Clearance ands all that and it was fine.I didn't use clay used check springs...if I would have used clay I would have caught it before I wasted a head gasket.
So tonight I put one on and after I torqued the bolts I went to turn it over and thud. I can't even roll it over. :cry: I took the other head and tried to lay it on the other bank with a piston at tdc and with no gasket I can feel it barely rocking around on the dome....Never thought to do that before cause I just figured they would fit cause my old ones did.( I know never assume)I don't know how I didn't catch it when I did the valve /piston clearance..it rolled over then(not torqued down)I did sorta feel something when I first turned it over...but just figured it was just from siting all winter.....cause I mean it was very very light...now obviously it is clear the piston must have just barely rubbed and then when I torqued the bolts down it hit. It is obviously hitting the head as visible through spark plug hole.My pistons only have a 36cc dome and the heads are 115 cc chambers. (I got those rather than the 119 because of the relatively small piston dome) .Brodix says they work with all standard pistons. My old 074 heads had been milled to hell and back and they cleared just fine...I even had them on a 454 with the TRW open chamber piston with a 48 cc dome and it was fine. This short block is new but I have ran it some last year with the 074 heads...I don't know off the top of my head how far in the hole the piston is...but it is NOT above the deck. I will have to measure it tomorrow... What are my options to fix this? I mean I know I could get different pistons or grind the heads but I don't want to do that(grind) cause I don't know what I'm doing and don't want to ruin a brand new set of heads. I know the 1017-2 is .051 thick but this is a dead thud so that wouldn't help I don't think...any advice would be appreciated. PISTON Are SRP and the PART NUMBER IS 140329 PS. No spark plugs or pushrods installed yet so it isn't that. I am going to cc one of the heads tomorrow and see what it actually checks at too. |
BB2 X tra
This is a pretty common problem with these heads. Either start working on the domes where it hits. Or do what I did made the chamber look like a Dart chamber. Mine hit with a set of Ross pistons.
This sure sucks, but not much to do but fix the problem. I went round and round with Brodix, and Ross. Sent pictures to both of them. Neither one did anything about it! Good luck!!!!! |
Re: BB2 X tra
This sure sucks, but not much to do but fix the problem. I went round and round with Brodix, and Ross. Sent pictures to both of them. Neither one did anything about it! Good luck!!!!! I don't know what a DART chamber looks like...I'll have to look for some pics online. How much work did ya have to do to the chambers? Where do they hit? I am going to put some dykem on the chambers and roll it over later and see what part it actually hits. Thanks for the reply. |
I had the same problem with a set of 2X's ..... didnt need no dyekem to tell where they hit that was for sure.
And I did as is described above. |
I had same problem last year. actually ran the aky engine. I ended up simply grinding the chambers at the point of contact. took care of the problem. on my set i didn't get technical just ground chambers. did this in about a hour. I run 8's with no more problems
| All times are GMT -8. The time now is 09:33 PM. |
