-   -   msd pro mag44 (https://www.racingjunk.com/forums/showthread.php?t=20567)
badluck9us 04-17-2008 06:20 PM
msd pro mag44
looking for info on how i hook up my tach and air shifter box need some sort of rpm referance some how any help would be appriciated
cpgeneration 01-28-2009 12:41 PM
mag 44
if you are running msd components the tach can be picked up off your timing ciontrol, if you do not have that component get a msd tach adapter for a mag 44. it wires to the coil P/N 8132. msd also makes a shift control that will work with a mag 44 P/N 7559 they both work well with the mag.. make sure you do not overload the tach port with a lot of items, shift control, data recorder, tach... K
