-   -   big brodie heads (https://www.racingjunk.com/forums/showthread.php?t=20499)
bakerboys 04-10-2008 07:23 PM
big brodie heads
i got a set of big brodie heads what should i do to them to beef them up
cepx111 04-10-2008 11:58 PM
Those heads are pretty stout and shouldn't need anything but checking for your particular combo, I.E> correct spring pressure, valve installed height, coil bind for the cam your running.
Are the heads new or used? What are you putting them on and whats the intended use?
Charles
Pwmax 04-11-2008 05:12 AM
Which heads are they? BB-2, BB-2plus, etc etc. Alot of the Brodix heads say, or said, Big Brodies under the valve cover. Then, the next question, what is the application, and engine combo?, and how fast are you teying to run? THose few questions need to be answered, before we can give you more info
Frank
Advanced Performance
www.get-ap.com
bakerboys 04-11-2008 09:20 AM
i dont know the exact numbers on them right now. i am off at college tryin to get some ideas or tips. when i get around them again i will post the numbers. they are used the guy who i got them from used them with a blower. i am trying to put together a 512 ci bbc with about 13.5 compression ratio car is a 1985 buick regal. i want to run 9 seconds with a hit or two of juice. the block i a 2 bolt main it comes out a 1991 chevy dully work truck.
OneBadGMC 04-11-2008 10:14 AM
If you can't run 9s without the bottle with a 512, Big Brodies, and 13.5:1, you're doing something majorly wrong.
hammertime 04-11-2008 10:27 AM
I agree :D :!: A lot of small blocks could power that car to the 9's big block will have no problem
jrthone 04-19-2008 01:56 PM
Check my Forum listings about big brodies. theres alot of good information from some good guys on there.
