timing
whats the best gear drive or timing chain bbc 512 13.0 to 13.5 compression
Re: timing
Re: timing
JMO Zip. |
I like the one made by Cloyes that has the slotted holes that you can turn the cam gear like a jessel. Alittle expensive for a chain but much easier than fooling with those bushings.
JMO |
Jesel............... :D :D
i prefer gear drives over chains,due to the the claims that are made of gear drives....google gear drive and read about them..
if your gonna go with a chain..get a cloyes TRUE ROLLER chain.. i agree with Zip on the brand of gear drive..i also run one in my 511ci and jessel belt drive on my 632ci |
if your gonna go with a chain..get a cloyes TRUE ROLLER chain.. i agree with Zip on the brand of gear drive..i also run one in my 511ci and jessel belt drive on my 632ci You can for sure spend more, and not get better. JMO Zip. |
| All times are GMT -8. The time now is 05:21 AM. |
