-   -   350 build question (https://www.racingjunk.com/forums/showthread.php?t=20470)
hardcase 04-07-2008 05:15 AM
350 build question
Building a 70's sbc and adding a set of 906 vortec heads, stock style roller rockers (1.5) with a low lift hydraulic cam (under .500). What should I use for a push rod the stanard lenght (7.793) ?
Thanks Hardcase
lanham 04-07-2008 04:29 PM
pushrod
You should be able to use the stock length pushrod but you still need to check to be sure.
