1050 Alky Barry Grant Carb Help
i bought a 1050 Barry Grant Alky Dominator Carb and i know NOTHING about carbs at all ( I allways run injection)... I had it up at the grove today and my first pass was a 9.63 at 139mph (very slow) with a lil 850 carb i was going 9.40's. any way the 2nd pass it went 9.57 at 140mph still slow but very unconsitant.... there was no temp build i left a 180 and went through the traps at the same temp... but the car poped like 4 times going down the track... no temp means it is fat but the popping means it lean right?
ok ill give some spect's jettin in carb is 160 front and 164 the back. The carb has bowl exstention's front and back.. aswell as jet exstentions (onley in back)... car spects 69 Camaro 3100lbs with a 461 alum rod motor w/bb2 xtra heads.. in my head the jets sound low b/c my old nickerson carb had 177 to 185 jets.... Any Help would be great thanks Bob Murphy Jr http://img208.imageshack.us/img208/5006/m5sr1.th.jpg |
Re: 1050 Alky Barry Grant Carb Help
ok ill give some spect's jettin in carb is 160 front and 164 the back. The carb has bowl exstention's front and back.. aswell as jet exstentions (onley in back)... car spects 69 Camaro 3100lbs with a 461 alum rod motor w/bb2 xtra heads.. in my head the jets sound low b/c my old nickerson carb had 177 to 185 jets.... Any Help would be great thanks Bob Murphy Jr http://img208.imageshack.us/img208/5006/m5sr1.th.jpg A really rich carb can give you lean conditions also. If it were mine I'd keep jetting it up untill it fell off in ET.. I'd start with 186's squared. I take it this car had a 850 alky carb on it ? If not did you change timing/plugs check float levels, pressure ? Just simple things to rule out. |
Can a very lean carb give you rich conditions??? yes it was an 850 alky, i checked flot levels when i put carb on.. |
Can a very lean carb give you rich conditions??? yes it was an 850 alky, i checked flot levels when i put carb on.. Not that i've seen if its lean its lean, but can be so rich it give you a lean condition. The BG may not be as good as your 850 was, BG is known for having very poor alky carbs. |
poor alky carbs??? unconsittant? or slower or both
my barry grant is a dominator and my 850 Nickerson isnt and what you said about the lean trick that would me put my jetting lower than 160... that sounds low dont it?? the 186 idea you said earler sounded more like in the ball park b/c i remember carb jetting beieng from 178 to 190 NOT AS LOW A 160 and thats where im at right now... lower # is leaner right? on my inj (terminator) it's lower# is fatter. |
kool thanks 4 the help,,, ill repost on sunday for a turn out of what happend ... im gonna put in 186 jets to start and go from there..
Hammertime... i went back up to the grove today and i put 185 jets in the car and it got worse.. last time my slow et was an uncosistant 9.63 and today it was a 9.67 @139 so my second t/s i through my lil 850 nickerson carb on it and went a 9.570 and backed it up with a 9.573 both @141mph... i dont know what to do wit this Barry Grant carb, i mean its like brand new is there anything else i can try?
| All times are GMT -8. The time now is 03:46 AM. |
