-   -   INTERNAL OR EXTERNAL (https://www.racingjunk.com/forums/showthread.php?t=20439)
jrthone 04-03-2008 09:57 PM
Can you use an external fluid dampner on an internal balanced motor???
cepx111 04-03-2008 10:24 PM
No.
If your motor is internally balanced you "HAVE" to run a neutral balancer, fluid damper and many other performance brands make neutral balancers. You also "HAVE" to run a neutral flywheel on a motor that's internally balanced.
GOODLUCK< Charles
jrthone 04-03-2008 10:55 PM
Thanks mate that answered my queston in one easy to understand sentance.
James Hone
edvancedengines 04-04-2008 12:33 AM
POssibly you can. Make a phone call to FluidDampener and ask if removing the extra weight on your dampener will be effective to do. Some of those do have a removabale conterweight on one side of dampener.
cepx111 04-04-2008 12:47 AM
Good point Ed, and your welcome.
Cp
