Is this the right combination?
I have a 468 BBC 4 bolt main, GM steel crank 4" stroke, eagle H beams 850 HP 7500RPM, srp pistons 48cc dome, doug herbert mach roller, 698 700 lift 269 277 @50 305 310 108 LC, AFR 335 cnc heads 2.30 1.88 121cc chamber, 1150 holly dominator, 2speed pg tranny brake,tubbed 83 camaro 32" tall tires and 433 gears. I want to run 8.60 in the 1/4. Please inlighten me on my set up.
Whats your car weigh?
times
Its been quite a few yrs ago, I had a all glass 84 firebird that weighed 2350 wet with a 468 that made 714 hp, ran 9.0s at 151. What are You using to figure the 850 hp?
EST
Better have about a 250HP Plate Kit under that 1150,to run the # you are after!
later G 8) |
My brother run's a 1986 dodge daytona, 2450 with him in it, 604 indy hemi with sheetmetal intake, 2 1050 with 200 shot, powerglide, dana60 with 4.56, 16x33, run's 8;40 1/4, if this combo helps.
Re: times
I'm with BBCHEVY on this one, your gonna need lots of spray to get them numbers. Your particular combo will net you about 700 to 750 poines. Goodluck<Charles |
Re: EST
later G 8) |
car weight
fiberglassed 83 irock 2650 with me in it.
you need 823.4520390598471 Horsepower to run 8.60 in 1/4 in a 2650lb car...
http://www.mindspring.com/~steveflye...hp_from_et.htm |
| All times are GMT -8. The time now is 01:43 AM. |
