how much hp to 9" houseing?
with a narrowed 9" houseing and rear brace, and 4 link. when is it nessary to go to a chromoly after market houseing. to what hp will it be safe to?
assuming you have
good axles 35 to 40 spline ( have seen 33 spline live) a good aftermarket 3rd member with billet caps ( pull thru bolts) set the car up with the 4 link with minimum body roll also depending on how much you narrowed the housing..this promotes strength in itself i have seen them run well over 1,000 hp..hooking with 1.12-1.13 60 ft's |
| All times are GMT -8. The time now is 11:49 AM. |
