ballpark horsepower guess of a 468 bbc
I just picked up a 468 shortblock that is 12.5:1... I have steel LS6 heads for it with a .718 roller and a Super Victor with a 1050 dominator...
I am just trying to get horsepower guesses... thanks for your input... |
655
heads flow ? the cam @ 50
Unfortunatly I dont know the flow numbers, they are ported a little. The duration @ 50 is 278... This is my first ever big block, I am setting this on my dragster, I was just wondering what horsepower it might be and what it might run at 1900 pounds....
thank you guys for help.. |
Should be a 5.30-5.40 car I'd think mid 600 HP
I would be very happy with that! somewhere around 8.40-8.50 in the 1/4?
David have you used a shorty glide in which the gear set was resplined to make it shorter? My shorty glide is a stock case with 1.76 stock gears that have been re-splined... It has the good high gear hub and clutches with a tci pro tree brake. Do you think it will be fine behind this motor? It worked perfect behind the 406 but I have heard mixed opinions on it behind the bbc... thanks |
These are my numbers below. My engine is approx. 700hp and the car weights 1850lbs. with me in it. I'm hoping to run a high 7 this year 8)
| All times are GMT -8. The time now is 12:16 PM. |
