-   -   vibration after torque converter install (https://www.racingjunk.com/forums/showthread.php?t=20378)
rabiddawg 03-28-2008 05:59 AM
problem is a slight vibration @around 4200 that i think is the torque converter.
im thinking that maybe reclock the converter to the flexplate ?
you think that might help?
zipper06 03-28-2008 06:09 PM
If it's possible, i would slide the trans back with the converter engaged to trans. enough to get an indicator up to the hub and check run-out while spinning the converter by hand, more than .002 it could be the problem. If there is no run out open up the flywheel hole 1/64" in case there is a bind.
bjuice 03-29-2008 07:39 PM
do you have the converter shimmed up to the flex plate? if so how much?
rabiddawg 03-31-2008 08:16 AM
didnt need shims
but I think the vibes are from a bad/wrong balancer.
still vibrates with converter disconnected
jmarksdragster 03-31-2008 08:09 PM
What engine?
rabiddawg 04-01-2008 05:50 AM
406 smallblock
johnracer 04-01-2008 11:00 AM
Is it internally or externally balanced? Stock 400 is external but the trend is to internal balance them for hp use. Flexplate and dampner are different depending on which way which way it's balanced....
rabiddawg 04-01-2008 12:08 PM
its extrenally balanced for sure
jmarksdragster 04-01-2008 12:40 PM
If you are using stock or stock replacement pistons , rods and crank you need the balancer and flexplate/flywheel for a 400. If any have been replaced with aftermarket parts the weight changes and the assembly needs to be balanced.
olds48 04-01-2008 07:23 PM
How much shim is acceptable?I'm running 1/4" :oops: Both converters I've run needed same amount.Seems like alot to me.Half tempted to order next converter setup for a mid-plate just to take up the slack
