-   -   1/2 or 5/8 rear wheel studs (https://www.racingjunk.com/forums/showthread.php?t=20321)
deepockets 03-23-2008 06:34 AM
i currently have 1/2 wheel studs on strange 35 spline axles. i really dont want to buy new axles to go to the larger studs if i dont need to. im i ok whit what i have. 1000 hp, glide, 2650 weight on car 15-33 slicks. thanks
suicidebomb 03-23-2008 07:41 AM
re; wheel studs
With that kind of horsepower I*d get the biggest stud I could get. But you don*t need new axles.
itsabird 03-23-2008 08:24 AM
in this case i would go bigger, it,s better to have it, and not need it, than need it, and not have it, with that kind of hp, i would want it.!!!
topcat572 03-23-2008 09:14 AM
studs
I got 5/8 on my digger with less hp, yes move up, You wont be sorry. 8)
Tod74 03-23-2008 10:35 AM
NO QUESTION....5/8!!
lively 03-23-2008 12:19 PM
???--DO YOU HAVE TO DRILL OUT YOUR ALUMINUM RIMS BIGGER OR IS THE LUG NUT SHANK JUST THINNER???
itsabird 03-23-2008 01:40 PM
lug nut,s for 5/8 will not have a shank.
deepockets 03-23-2008 05:29 PM
the wheels will still work, wondering if the axls will be ok to br drilled, or are they hardened after there done from manufacture. i guess i can call strange tommorow
sg5492 03-23-2008 06:37 PM
Re: studs
I have less HP in my 69 and have 5/8
suicidebomb 03-23-2008 09:09 PM
They can be drilled.
