alchol problem
we have a problem with the engine milking the oil on a full pass, not a problem at idle or warmup the car has lost 5tenths and 4 mph this is a overnight problem also blowing oil out the breathers
Thanks,Thad |
May have a blown head gasket. Are you loosing water?
alchol problem
No, that was checked, this is wierd, we have ck everything of that nature
Thanks,thad |
In that case, something is forcing it way rich. I'd check the bypass. Pill might be plugged or something else restricting it. The blowing oil out of the breather might indicate a broken ring. Should do a leakdown test to confirm.
re; alcohol problem
alchol problem
Thanks, guys it is a carb, we are familier with injection, lost on the carb did a lleak down test 2701pis with 4percent leakage
Thanks Thad |
a float stuck ? how about a fuel filter ?
Are you running a belt drive pump or electric?
alchol problem
The filters are ok no floats sticking
WE ARE RUNNING ELECTRIC PUMP FUEL PRESSURE STAYS THE SAME NO RISE OR FALL Thanks,Thad |
Maybe one or more of the jets have fallen out. Don't laugh, I've actually seen it....
| All times are GMT -8. The time now is 11:30 AM. |
