-   -   ARP OIL PUMP STUD? (https://www.racingjunk.com/forums/showthread.php?t=20286)
HUNTER39 03-19-2008 04:51 PM
ARP OIL PUMP STUD?
On a sbc what should I torque a arp oil pump stud at?
topsportsman1 03-19-2008 05:03 PM
http://www.arp-bolt.com/catalog/catalog.html
jmarksdragster 03-19-2008 08:06 PM
Check very carefully or this one will bite you, if you are using a stock block, make sure the stud does NOT extend into the bearing especially on a 400, don't ask how I found out. :cry: Aftermarket blocks should be OK.[/list]
