-   -   Throttle Linkage ? (https://www.racingjunk.com/forums/showthread.php?t=20276)
keb1 03-18-2008 03:34 PM
Throttle Linkage ?
Engine: 496 BBC
Carb: "Quik Fuel" 950 cfm Holley
My present gas pedal to carb linkage is just a hollow rod.
Both ends are female taps.
I have small clevis ends threaded into each end.
Also a pretty cheap throttle return bracket with 2 springs.
I have seen a multiltude of throttle linksage brackets from various
companies in the Summit / Jegs catalogs.
Some can get pretty pricey.
I have no plans on using a throttle stop.
I run IHRA "NO BOX" class
Can anyone suggest one that they are happy with?
bigs1975 03-18-2008 05:45 PM
The Jegs bracket with the return springs are very nice.Alot like the CSR peice.For $60 it can't be beat.
mopar1968 03-22-2008 09:09 PM
throttle linkage
Contact Ron owens on here he just set me up with a throttle linkage, ran it tonight, worked great!!
Tod74 03-22-2008 09:40 PM
x2
keb1 03-23-2008 02:31 PM
I couldn't find Ron Owens phone or email.
The members list (In the Help forum didn't give his name)
I am definetly interested.
Keith B.
curtisreed 03-23-2008 03:16 PM
http://www.ronowensracing.com/
jaht1320 04-06-2008 04:58 PM
What's wrong with running solid linkage? As long as you have solid motor mounts, I would stick with what you have.
olds48 04-07-2008 07:06 PM
Solid linkage with a toe hook.Only way to go IMHO :D
bryanm 04-08-2008 09:52 AM
I run a bracket I hot from Holcomb Motorsports. It has the double rerturn spring attached to it and is in a polished aluminum finish. It is a very nice piece and I payed $110 for the bracket and a cable.
zipper06 04-08-2008 10:41 PM
It doesn't matter what you run for linkage, just make sure you have a toe hook to bring the throttle cable/rod back to "0" it's the quickest respond to a stuck throttle on the top end.
