-   -   MSD Chips (https://www.racingjunk.com/forums/showthread.php?t=20267)
rlgodbold 03-17-2008 08:27 PM
MSD Chips
I've got a 6AL for a 4 cylinder Mod 4 Ford 2300 engine. It has a rev limiter chip in it but does not have a chip specifying 4 cylinders. I was thinking that it needs that. If it does where can I find one? Thanks.
johnracer 03-18-2008 02:37 AM
Your 6al should be set for four cyls. The chips are the same for all.
edvancedengines 03-18-2008 06:58 AM
The Revv Chip is really only a plug in resistor of a certain value.
Number of cylinders means nothing to the chip.
Ed
jmarksdragster 03-18-2008 08:08 AM
There is no difference as Ed said an MSD chip is nothing more than a resistor like what you can buy at Radio Shack. Before the digital boxes I made rotary dial two step boxes, the two step was nothing more than a relay to switch between resistors for a rev limiter and a low side for the brake. I built a couple different ones, one with a rotary switch with progressive resistance values to increase or decrease RPM as needed and the other with potentiometers which are variable resistors. I also got the resistance so I could set the low side below 3000 RPM which was the lowest chip MSD had at the time.
hammertime 03-18-2008 12:01 PM
I agree you need to set it for the 4 cylinder, if I remember right one of the boxes has a few different looped wires coming off the side and you cut the one for the 4 cylinder
Racefab57 03-18-2008 04:32 PM
Its either cut one or cut two of them, Call msd!!!! or see THE instructions, LOL David
sds10racer 03-18-2008 07:41 PM
when all else fails, follow instructions is my motto :)
jrthone 03-25-2008 01:41 AM
Blue wire
