-   In The Pits (https://www.racingjunk.com/forums/forumdisplay.php?f=18)
-   -   water pump (https://www.racingjunk.com/forums/showthread.php?t=20257)
mark468 03-17-2008 12:03 PM
water pump
what is everyone using for a alt bracket?have a BBC with CSR ELECTRIC PUMP would like to keep it on the pass if possible
thanks
johnracer 03-17-2008 03:39 PM
I have an Eastcoast Supermini and mount on mine. It'll mount on either side.
spib 03-17-2008 03:50 PM
http://www.alangrovecomponents.com/B...ctric_Pump.htm
earthquake 03-23-2008 05:49 PM
My engine and trans were solid mounted, so I took the factory upper bracket and flipped it upside down and welded it to the frame. Then I used the factory pivot bolt on the other side. It worked great as a low mount bracket.
