-   -   OIL PUMP (https://www.racingjunk.com/forums/showthread.php?t=20245)
Racefab57 03-16-2008 01:30 PM
OIL PUMP
I just got a Jeff Johnsons wet sump oil pan for a sbc its a box style pan BUT it only measures 7 5/8 deep I bought it on RJ Great looking oil pan BUT moroso's billit pump you need 8 1/4" others of which I cant remember off hand, DAM 51yr old brain cant remember S%$# but HELP havnt tried titan yet but dam there $7-800 !! I can do an exterenal pump for about that and be able to prime oil system before starting . OH WELL lets see what you all have to say, THANKS VERY MUCH David.
lanham 03-16-2008 04:06 PM
oil pump
Check with CVR they make a nice alluminum bottom feed oil pump.
edvancedengines 03-16-2008 06:51 PM
Jeff's pans usually have a part # on them somewhere.
Most of the Billet Fab wet sump pans are built so they can use the Titan Gerotor Oil Pumps, which in my opinion is the best wet sump oil pump money can buy. A Titan Pump should be on every wet sump performance engine there is. The cost is a lot but is cheaper than the cheapest engine is. I am a WD for these Titan Pumps but also that CVR Pump might work for you. Never used one yet, but for a regular Spur Gear pump they do look pretty good.
Ed
