Lifter bore problem
I need to find out how much lifter bore clearance is acceptable. I had some issues with low oil pressure in a race engine of mine and one of the lifters got a bit stuck in the lifter hole. I had to use a pry bar to remove it and it looked scorched.
I dont want to throw the block away but may have to. any easy fix for these? Al |
Re: Lifter bore problem
block is sbc 509 casting.
lifters are solid roller, crower I think. Al |
| All times are GMT -8. The time now is 09:26 PM. |
