-   -   Header Question on a 632 (https://www.racingjunk.com/forums/showthread.php?t=20163)
blaserman 03-09-2008 02:53 PM
I have a 72 Chevelle ansd am putting together a 632 10- 1/2 to 1
motor. with the tall deck what headers do I need will hooker Super Comp work or do I need special Headers.
sc3314 03-11-2008 06:32 AM
Headers
What heads are you running on the engine? With the T/D and any head with a raised exh. port you are going to have some problems. If the front stub has been done you have a better chance of getting some to fit.
But be ready to change a few tubes, it may be your only hope. Super Comps. in my Nova 540 T/D .400 raised exh. port We changed 4 tubes, and the front stub was done. Plated, crossmember cut, and a rack.
You can try Kooks, or Lemons they may have something that might work? But they will cost almost as much as a fabbed set will run you.
Good Luck
