-   -   heads & piston (https://www.racingjunk.com/forums/showthread.php?t=20082)
ima400 03-04-2008 10:29 PM
heads & piston
hi guys just woundering if anyone has done this exercize .
i have a 414 sbc with 23deg heads , im thinking of changing to a set of 15deg or 12deg . can i get away with yousing the same piston its a JE with an 11cc dome ?
cheers chris
edvancedengines 03-05-2008 12:40 AM
Yes you can.
The valve notches on the pistons will need to be compltely redone though.
Ed
ima400 03-05-2008 07:57 PM
Originally Posted by edvancedengines
Yes you can.
Ed
thanx ed so all i have to do is fly cut the pistons & all is good yeh , cool
