What is the torque you tighten the screws on the Bead Lock?
Just checking to see what is the torque if any on the screws to secure the bead? Thanks
depends on the grade of the bolts. champion beadlock says 15 lbs on grade 8 and 20lbs ob there 12 point bolts
| All times are GMT -8. The time now is 02:50 AM. |
