-   -   tires and gearing (https://www.racingjunk.com/forums/showthread.php?t=20022)
Xrated1 03-01-2008 09:56 AM
tires and gearing
I need to slow my rpm down 300 through the traps, now running 456 gears and 32 inch tires @ 7000 rpm how big a tire do I need to get to 6700? I would like to do this with a bigger tire rather than changing the gear if its possible.
fla1976 03-01-2008 12:59 PM
Tire
If you go to a 33.4 inch tall tire it should drop you 300 R.P.M. and maintain the same speed.
sds10racer 03-03-2008 07:47 PM
try changing a shift point. i'm using 4.86 gears and go thru the lites at 6800 using 31-10.5w's.
