air fuel ratio
whats is the best air fuel ratio set up for racing? have a air fuel meter that i got from a friend,and checked my motor.At 4800 to 5000 rpm it is around 14-9 15-2. is that a little lean 509 cid 950 carb
That's darn near impossible to answer because of the factors involved.
Intake, exhaust, compression, heads, vacuum, and weather variables play too big of a part of it. Every motor is going to have it's own 'fine point' with a/f ratio. What's going to do the most justice for you is to find your best et, noting the a/f ratio and shoot for that ratio as weather conditions change. Tuning for a specific a/f ratio or egt requires the use of a weather station and a knowledge on jet area as it relates to egt or a/f ratio. |
a/f ratios
i would go to Innovate motorsports . They have a form there and all they talk about is AFR. they can answer an guestion about AFR
Never used a density gauge, sorry.
I have a Computech RaceAir Pro 1000. http://www.computechracing.com/Produ...-portable.html I don't know how I got along before I bought it. |
| All times are GMT -8. The time now is 03:26 AM. |
