Dyno #'s are in
Just got my motor back from the Dyno @ Nyes Automotive in Muncie Indiana. This time I decided to dyno it with a 1250 Gas Rupert to break the rings in and get a good comparsion between the Terminator and Gas.
This is a 582 CI Motor Eagle insides, Erson Cam 806/765, BMF 385 Heads, Sniper Intake. 1st time it made Average 948 HP 814.39TQ Peak 964.5 HP @7200 819.6 TQ @ 5300 Rpms Terminator & 37 degrees timing. 1250 Rupert gas Carb Average- 919.5 hp 776.71 @ 5050 Rpms Peak - 939.9 @ 7000 & 800.2 TQ @ 5400 Rpms Timing was 38 Terminator HP TQ 5000 773.4 812.4 5500 856.4 817.8 6000 924.8 809.5 6500 957.9 774 7000 963.6 703.6 Carb HP TQ 5000 736.5 773.6 5500 837.3 799.5 6000 900.1 787.9 6500 936.2 756.4 7000 939.9 705.2 |
Nice, that should spin the tires a little. :lol:
Remember a bit ago, about in the thread about 23 degree heads? Where I talk about making power with heads that aren;t supposed to? Well, this is a perfect example, and I am not posting this to steal your thunder, or hyjack the post. But, BMF's are considering by many, the best conventional BBC heads available, and the Sniper intake the same. As a comparision, I have a 580 in the shop, that I did last year, actauly, just ported the heads and intake, on an existing short block. Canfield 350's that I ported, and a Super Vic. that I ported. Tall Deck block, 4.53 bore with 4.5 stroke. Heads were 375cc final port, flowed 438 max cfm, 13.5:1, a cam with .797 intake, .770 ex. before lash With a 1050 carb, for a throttle stop application, it made 952hp at 7100 and 787 ft/lbs at 5500. It was sucking over 2 inches of manifold vacc. With a bigger custom carb, it would have easily made more. I am completely redoing the engine, 598 inch, ported 18 degree Chiefs, Edelbrock single 4 intake, 1250 dominator, that I will tune up a bit, 15:1, a more radical cam, so, it should wake up a bit. I just want to say I appreciate you posting those numbers. Its always nice to compare numbers from different combos, and, reinforces for me, that my stuff works pretty good compared to the big named guys, again, with castings, that most guys wouldn;t think couldn't hang with the BMF's Yours should run very hard, and its not overly radical, so, it should make many passes. Thanks Frank Advanced Performance www.get-ap.com |
dyno
Which car are You going to put this one in?I know where You can get a good converter,lol,TC
Re: dyno
Its going in the orange car, the only one I have left right now :D Never know in a few months though :wink: Waiting to see what the #'s are with that convertor !! Still betting on a faster copy machine ! |
hey hammertime did nye,s build the motor, or did you just dyno it there? if it,s the same people i,m thinking of, they make dang good h.p in pulling trucks. but the name pat kinda throws me.
They built it last year and freshened it again this winter. Pat is Mark's brother its a family busniess. Pat is a drag racer the rest of them are into pulling trucks. They do nice work. |
HeHe, Hey David, Watch out for Alwayconsistant, cause he'll whip your butt no matter how much HP you can produce.
:lol: Zip. |
:lol: Zip. |
i have a couple of buddy that pull truck,s, went to a few pull,s so got a chance to hear and see their h.p, (nye,s ) motor at work, i was impressed, so give,em heck with your,s this year.
| All times are GMT -8. The time now is 10:09 PM. |
