Rolled quarter panels...NEW Picture included!
Hey guys need some opinions.
I just bought a car that has one quarter panel rolled under. They cut the lip about every quarter inch just enough to bend it up under to allow for larger tires. I guess they didn't like how it looked so they left the other quarter alone. What's a good way to fix this? I am concerned it's going to start to rust. I've though of grinding it down and using some POR15 on it as it is unseen. But I'm wondering if theres a better way. I want to keep the resale on the car valuable. Your suggestions are welcome, and keep in mind, I'm not a body guy. |
What type of car is this your speaking of ?
a pic would speak a thousand words.. i am not a full time trade body man but i have done my share of patch panels,rocker panels and worked a little bondo...( but no paint,,,just prep) |
Here's a good picture. Its a 93 Mustang GT. As I said it can't be seen unless you look under the quarter panel. But it's a hack job, for sure, on an otherwise flawless car.
http://i258.photobucket.com/albums/h...3/100_0151.jpg |
Wheel Well
You should be able to find a replacement panel and if you don't know how to repair it yourself, you could have a body shop replace it. At least they stopped after messing up the one side!!
The last thing I want to do is replace the whole panel. I'm looking for options on repairs, not complete replacement and a repaint.
that can be fixed if i am seeing all the damage in the picture...
good bondo man ,die grinder,,,got as knew... Don't let the word Bondo scare you...if its put on proper ( surface VERY,VERY CLEAN)...it will hold up for years.... Brian |
| All times are GMT -8. The time now is 11:54 PM. |
