-   -   Protecting sand blasted intake???? (https://www.racingjunk.com/forums/showthread.php?t=19863)
TonyJJ 02-15-2008 05:03 AM
My aluminum was looking bad, so I sand blasted it with aluminum oxide blast media. It look great right now ,but I know the finish will get dull. I was going to use a walnut shell media next to see how good it l looked. Does anyone have an idea on how to protect the finish on this intake? I have used a clear polurethane from Eastwood, but I did not like the results after a couple of months. Maybe power coating is the answer.
Thanks
Tony
Racefab57 02-15-2008 05:13 AM
Powder coat it !!!I did and it always looks good!!!!!!!!!!! David
hammertime 02-15-2008 11:43 AM
send it to Nitro Plate and get it coated !
itsabird 02-15-2008 02:01 PM
i would say intakes are made from 6061 t6 alloy, so if there is a process where it can be plated, that,s your best bet, or powder coating, otherwise be prepared to do a lot of buffing, and blasting.
bignastygs 02-15-2008 03:26 PM
I had mine done as well as the timing cover in an aluminum powdercoat for my Buick. Still looks like brand new. Total cost from my guy for both pieces...$85 bucks!
[imghttp://i196.photobucket.com/albums/a...OTORMedium.jpg][/img]
bjuice 02-15-2008 06:03 PM
i paint my single carb intakes Black...MY Taste i guess.
edvancedengines 02-15-2008 06:41 PM
No one has yet mentioned this, but I would be much more concerned about what the blasting did inside the manifold. Sand blasting an intake manifold can be very bad. No matter how hard yopu clean the media or sanding particles will be imbedded in and will get into your engine.
The outside is easy. Powder coat. Polish and clear coat. Paint with engine paint.
Ed
bignastygs 02-16-2008 04:00 AM
My powdercoater guy placed bungs into all holes to keep the blasting media out of it. He has some sort of pliable rubbery stuff that presses into the holes then expands to keep the media out. None was in the intake when he was finished and even then after several minutes and times being blown out,did anything come out. He is really particular in his ways. I realize not everyone is like him so you need to keep an eye on your powdercoater guy.
Tod74 02-16-2008 04:12 AM
I used to do that. My first engine when I was 18 yrs old I painted everything black. :D Brand new intaske included. My dad said I was crazy. I think it looks good.
v8Fiero 02-16-2008 04:48 AM
I forgot where I heard this but I heard that black and chrome are the two worst colors to have on an intake manifold because they absorb light and heat up the intake. and aluminum like the pic above is the best because it doesnt absorb as much light and heat. Im sure it doesnt matter as much if it is under a closed hood but can anybody comment on this, if it is just an old wives tale or if there is something behind it?
I agree that black and chrome look awsome but it wouldnt be so cool if you loose ET because of it...
