-   -   WHEELS (https://www.racingjunk.com/forums/showthread.php?t=19852)
lively 02-13-2008 08:07 PM
WHEELS
IS THERE A SIMPLE WAY TO TELL WETHER A WHEEL IS MAGNESIUM OR ALUMINUM????????WITHOUT PUTTING A FLAME TO THE WHEEL!!!!! :cry: :cry: ---LIVELY
olds48 02-14-2008 01:11 PM
I'm glad you asked 'cause I was wondering about the front wheels on my rail.
fla1976 02-16-2008 06:40 PM
Mag wheels
Found an article that gives the following info: When it is submerged in water, hydrogen bubbles will almost unnoticeably begin to form on the surface of the metal, though if powdered it will react much more rapidly. So I suppose if you submerge them and look for hydrogen bubbles to begin forming it will tell whether it is magnesium or aluminum. Sounds alot safer than the flame test.
olds48 02-17-2008 03:11 PM
Which one will bubble?Aluminum or the mags?What is a hydrogen bubble :oops:
feenst 02-17-2008 07:37 PM
Found this:
http://www.jalopyjournal.com/forum/s...ad.php?t=77287
About halfway down it says that putting vinegar on a magnesium wheel will cause it to fiz. It won't fiz on an aluminum wheel.
Hope this helps a little.
Jamie
lively 02-17-2008 09:16 PM
Originally Posted by feenst
Found this:
Jamie
ALOT OF INFO FROM ALL YOU GUYS------I WILL TRY THE VINEGAR DEAL AND FIND OUT 8) 8) 8) THANKS ALOT --- LIVELY
olds48 02-18-2008 05:55 AM
8)
