-   -   timing alcohol (https://www.racingjunk.com/forums/showthread.php?t=19822)
kmcclain 02-10-2008 06:39 PM
timing alcohol
I have a 468 BBC 13.1 comp. 1050 carb, it runs pretty good 17 initial and 34 all out but a little harder to start,and what rpm should it be all out at?
cncmotorsports 02-10-2008 06:55 PM
Total timing advance should be checked at 2500 - 3000 rpm
Depending on your cam size, you might want to lock the distributor and just set the timing at 34 – 36 degrees..
kmcclain 02-10-2008 07:39 PM
timing
thanks ill try that
SPEEDNEEDS1 02-10-2008 07:50 PM
Lock the dist. out and time it at 1000 rpm or 10,000 rpm and it will be the same, 34-36 on alky is about right.
kmcclain 02-10-2008 08:17 PM
alky
thanks you guys.
Tod74 02-10-2008 10:56 PM
If you lock it out you will know what it is at when you drop it in. If your balancer is degreed.
hammertime 02-11-2008 02:24 AM
I agree lock it out, my 468 liked 38 degrees timing, every motor is different.
