-   -   very successful (https://www.racingjunk.com/forums/showthread.php?t=19799)
hughesis21 02-09-2008 01:03 AM
very successful
i put together the standard 388- 4.060-3.750-6.0 rods
made 593 ft tq and 529 hp with 1200 dollars
this didnt include my machine work for block prep,or block and intake system running billet hei dist no spray,
running a tpi with siameized intake, cant remember the injector size but its 30 somethin, with a 58 mm tb 1200 dollars i said 1200 dollars
crank rods pistons bearings cam timing gears lifters roller rockers all summit brand or cheap brand parts, now ive only had the motor together for about 3 weeks now but when i put it in my all metal full interior malibu and it last longer than the crate motor i bought with less hp and tq im goin to go nuts :twisted:
amal 02-09-2008 02:40 AM
What is the camshaft are using for this combination
v8Fiero 02-09-2008 05:09 AM
wow, very good numbers. 8) Im interested in more details aswell, cam specs, what gen block, heads, compression, etc....
thanks :D
fla1976 02-09-2008 05:25 AM
Engine
Impressive results for so small an investment. Great combination obviously.
hughesis21 02-09-2008 08:30 AM
Part Number: LUN-60105LK
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,500-6,500
Intake Duration at 050 inch Lift: 241
Exhaust Duration at 050 inch Lift: 249
Duration at 050 inch Lift: 241 int./249 exh.
Advertised Intake Duration: 284
Advertised Exhaust Duration: 292
Advertised Duration: 284 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.525 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.546 in
1972 block- 1998 vortech heads 10.4 to 1 inverted dome heads have pocketporting couldnt find this cam as a summit brand
cncmotorsports 02-10-2008 04:49 PM
did you dyno the engine to obtain these numbers ?
hughesis21 02-10-2008 06:02 PM
grooms engines dynoed it, i have a buddy works in management over there
cncmotorsports 02-10-2008 06:15 PM
do you have the dyno sheet's ? Sounds like they inflated the numbers or did soemthing.
hughesis21 02-10-2008 11:42 PM
yes i have my own dyno sheets, this is not one of there production motors, so they have no reason to jack the numbers up, you just have to know what works with what, im not gonna buy a bunch of parts that have big names or look pretty, like most of the unexperienced motor assemblers. to tell you the truth i believe im holding some of the horsepower back because of the tpi setup. but i like the reliability of fuel injection. i believe i can run 7.00's n the malibu with a ten inch tire, beefy 700r4 4.10's and then drive it home, ahhhh fuel injection, somebody remind me to cage the car....
hughesis21 02-10-2008 11:51 PM
is the "inflation" accusation because i didnt buy the parts from your cnc-whateverucallit.com????? :idea: :idea: :idea:
