How do i remove the lower a arms in a 83 camaro
I think i want to change my motor mounts and the best way i see of doing this is to remove the lower a arms and go through the spring pocket to get to the back bolts on the mounts, also i want to change the bushings to the hodchkis ones, i guess i was wondering if i could do this in my garage at home or do i need some special set up, worried about the spring tension. thx to all
i used spring tension supressors and you can also use a floor
jack after popping the tierod out, and you will need a press to get the new bushings in the arms, i had a brake shop do the bushing for 10 bucks for upper and lower, polyurathane with a little grease, carefule with the springs, gearheads have been killed from the springs, good luck :? |
well i got the springs out and i am still alive lol, what do you guys think about dropping the k member out while i have it tore down this far, and maybe even putting a spohn tubular k member in it what do ya think
upgrading for more torque is always a good thing :lol:
| All times are GMT -8. The time now is 02:01 AM. |
