-   -   What's your altered weigh? (https://www.racingjunk.com/forums/showthread.php?t=19749)
slowmotion 02-04-2008 09:14 AM
I'm trying to figure out what my car will end up weighing.
It's a 150 inch Bantam.
We will probably put a iron head bbc in it.
slowmotion 02-04-2008 09:19 AM
Here it is
http://static.racingjunk.com/1/ui/0/...R-DOOR-CAR.jpg
hammertime 02-04-2008 10:49 AM
One buddy has a 23T with a sbc in it he is around 150-165lbs its 1800 with him in it.
nitro63 02-05-2008 12:26 AM
if you dont have scales to weigh the car, take it to a truck stop , unload your car and drive it on the scale and pay the charge
slowmotion 02-05-2008 02:54 AM
There is a couple of places in town I could probably do that, but I don't have a engine in it yet. I was just trying to figure out what it will weigh when done.
Thanks guys for the responses.
zipper06 02-05-2008 10:56 AM
I seen one on the scales last yr. with a rat, that weighed 1630 no driver, so 1800lbs sounds realistic.
nofear57 02-05-2008 12:21 PM
Mine weighs 1,650lbs without me in it. Sbc w/alum. heads,2-spd,small rad under the front,all fluids and 3 gallons of methanol and crome moly chassis.
feenst 02-05-2008 02:49 PM
Our fed weighs 1400 with an aluminum headed small block and rad, no driver.
slowmotion 02-05-2008 04:37 PM
Thanks guys.
We were guessing 1800-2000.
bjuice 02-05-2008 05:26 PM
1500lbs w/bbc......2050lbs with a 150lb driver with a set of 400lb balls to drive it.... :shock:
[img]http://i210.photobucket.com/albums/b...n/altered2.jpg[/img]
