-   -   Need help on BBC heads (https://www.racingjunk.com/forums/showthread.php?t=19715)
shockers69 02-01-2008 01:42 PM
I have a set of heads cast #6272990 one is cracked.i am going to a big swap meet Sunday in Nashville TN. and i would like to find a head that will match my good one.What other numbers would work and look the same outside?Please help ASAP!
itsabird 02-01-2008 02:19 PM
you may want to take a look at a 14096188.
OneBadGMC 02-01-2008 02:29 PM
http://www.gmpartsdirect.com/perform...CATID=361.html
There's a chart at the bottom that should help you identify all the common GM heads (made by GM).
