fuel lines
I am installing new fuel system. What do you think, aluminum hard lines or steel braided lines? good and bad of each.
Thanks |
What are you planning on doing with it ? street car, race car ?
I personally will always use braided line. |
buy the time you buy aluminum line and all the little fittings, you may as well spend a couple more bucks and get the braided.
Do not run aluminum line directly to electric fuel pumps...., not that it is dangerous, but the noise of the pump will resonate throughout the chassis, at least it did with the holley blues, I tried. Isolate them with a little braided.... |
Aluminium line will be harder to bend into place with a body on the car, I did a 64 Malibu I had years ago w/ the body off .. wasnt bad at all. Braided line I have heard from many that fumes will seep out.
I changed my car over to braided line and never experienced the fume issue and parked my car with the rear 5' away from a gas water heater ... and my wife can smell a fly fart from 50' away and she never complained. So I dont know how valid that point is. I have probably used SS line from every supplier there is w/o issue. I've also heard about the alum. line " work hardening " over time and cracking. I ran it on a street / strip car for over 10 years with no issues. I'm pretty certain the Alum. line will need to be run through a steel sleave in the flywheel / flexplate area to meet NHRA specs. Thats what I did. An FYI .. If you go the alum. hardline route, buy it from an A/C supply house and you'll pay about 1/2 of what a " speed shop " charges Just passing along info I have experienced and heard about. |
depending on what you have this is also a option it is nhra legal http://www.jegs.com/webapp/wcs/store...erm=799-634200
For the underside of the car, you can get DOT braided lines that they use on tractor trailers. It has a black cloth braiding over the stainless metal braids. Doesn't look pretty, and it uses steel ends instead of aluminum, but it costs about 1/2 the price as the racing hose.
Personally, I wouldn't use aluminum line. Dents, work hardens, and cracks from vibration. But, to each their own... If it works for ya, use it! |
Thanks all. With your info I have decided to go with the steel braided lines instead of the aluminum hard lines.
I love this forum. |
| All times are GMT -8. The time now is 07:46 AM. |
