-   -   What starter to buy (https://www.racingjunk.com/forums/showthread.php?t=19642)
lmchevy 01-26-2008 04:36 PM
What starter to buy
What kind of starter would you buy for a 15.1 632ci.I have the small CVR starter that has been a great starter but it doen't have the power to turn this engine fast enough and start it.Just wondering what everyone else is using on the big cube motors.
sc4405 01-26-2008 05:57 PM
starter
You'll get alot of opinions on this, but I'm sold on the GPE starters. Really good people to work with too. 8) JB
zipper06 01-26-2008 10:30 PM
I'm not partical to them, just because i sell them and i donot sell on RJ, but the ProComp PC2106 is a 3HP with 4.1 gear reduction and i've sold over 30 of them and have never had one returned in 4 yrs.(i won't sell you one here on RJ), but you can get one from their website and it will cost you less than any other starter listed that i know of.
deepockets 01-27-2008 05:42 AM
yes a lot of opinons, i like the #9400 powermaster from summit, i've gone thru the starter game and this works even beter than there more expensive 9400 that i sent back. if you dont already have the 16 volt there is another step again. one you have the 16 v you'll never go back. i have great luck with the 16-12 volt v-power from jegs, 565 ci 15.1
shawnp 01-27-2008 05:54 AM
I would check into the CSR 24 Volt set up. Very nice, but is a little pricey. We have run th CSR Platinum series stuff with no problems.
OneBadGMC 01-27-2008 08:39 AM
http://store.summitracing.com/partde...5&autoview=sku
I've been running the 2.4 HP CSR for almost 8 years now without any issues at all.
This was on a 505 with 11.5:1 static compression, plus the drag of a 10-71 blower on top. That starter on 12V provides plenty of cranking speed with a 168T flexplate to spin the motor at a speed that the mag will fire.
hammertime 01-27-2008 11:45 AM
http://www.jegs.com/webapp/wcs/store...10002_35690_-1
Tilton Super Starter, I've had 2 of these for years one for the trailer and one for the car. Right now I have it on a 582 with 14:1 compression.
Another tip for big inch motors, a start retard is a nice thing to use.
scuncio 01-27-2008 04:39 PM
I have never had a problem with the Big Tilton super starter, I currently have one with 16 volts- cranks like a son of a gun on a 555.
