-   -   need carbs for sheet metal intake (https://www.racingjunk.com/forums/showthread.php?t=19622)
ford344 01-24-2008 02:04 PM
looking for a pair of 750 cfm carbs set up for a sheet metal intake.
olds48 01-24-2008 07:22 PM
Just out of curiosity,how are they different from regular carbs?Thanks
ford344 01-25-2008 01:15 PM
tunnel ram carbs
they are calibrated at the factory so as to work as pairs in tunnel ram use.
bjuice 01-25-2008 02:10 PM
ok..do you have a Sheet metal intake or a tunnel ram?...the difference is like Night and Day in performance,look and price.. :?:
dcarr511 01-25-2008 06:52 PM
Re: tunnel ram carbs
Do you have any list #'s ( holley ) to go by ?
I've never heard of a 750cfm " calibrated " from Holley for a dual quad set up. I know they used model # 4160's for Dual Carb set ups due to the overall length when carbs are mounted front to back
I know of a few 4500's intended for Dual Carb set ups, like the 9375's but I have seen plenty of them used on single carb set ups and never seen them sold as pairs.
bjuice 01-26-2008 04:53 AM
i 2nd that
ford344 01-27-2008 04:43 PM
i am having a sheet metal intake being made to fit 302 block and 225 afr heads. thanks for your input
