-   -   rebuild roller rockers (https://www.racingjunk.com/forums/showthread.php?t=19606)
et7333 01-23-2008 11:55 AM
Anyone know of a company that rebuilds sbc roller rockers?
hammertime 01-23-2008 12:54 PM
Re: rebuild roller rockers
Call the company that orginal made them
et7333 01-23-2008 01:34 PM
I purchased from Summit,which are Summit brand
OneBadGMC 01-23-2008 02:05 PM
Sorry to say, but those are probably going to be disposables.
You could try a local tool and die shop.
You could also probably do it yourself. Assuming the bearings are just a press fit, with a "C" clip retainer on either side of the shaft.
http://www.bocabearings.com/
Pull the bearing out and mic it. Boca has some high grade stuff that I'm sure would work, and would probably be better quality than what it came with.
et7333 01-23-2008 02:55 PM
Thanks for the info
