what rivets to use
When tubbing a car what is the best kind of rivet to use?I'm using aluminum right now,just wondering if they will loosen and if I should go with steel or even exploding rivets
If you have alum tubs, use alum rivets!!! Using steel against the alum will cause corrision called electrollis, ( DISSIMILAR METALS) not a good speller sorry,Went to trade school instead!!!!!!!!!!!! David.
:shock: How serious is that :shock: I never thought about this til recently.I got steel tubs,but have over 400 aluminum rivets in place now.Nuthin rong wit yure spelin :D
also be sure to place the smaller flat washer on the backside of the rivet so it pulls up tight and displaces more holding pressure to surface.
Brian |
look for aluminum rivits with steel nails, (hard to find), I have made my own by buying both steel and aluminum and changing the nails..... :shock:
The aluminum nails I find are almost useless, as they seem to break long before the rivit is pulled tight. The other option is to use stainless steel rivits, the wont corrode the aluminum. |
Thanks for the info guys.Like I said,I have a few hundred rivets in place now.Aluminum 3/16.Will they work loose being a soft metal or should I drill them out and use something else?
if they are in there now, and they pulled up tight, leave em.....
NO MAN--I THINK YOU SHOULD PULL THEM ALLLLLLLL OUT :lol: :lol: :lol: :lol: ---LIVELY
:shock: Not you again :mrgreen: :mrgreen: Seriously,you think I screwed up?It would suck to pull them out,but whatever it takes to make it last
NAW--IF THEY ARE TIGHT --LEAVE THEM ALONE---JUST CHECK THEM ONCE IN AWHILE TO MAKE SURE THEY HAVEN'T LOOSENED[ THEN REPLACE AS NEEDED] 8) 8) 8) THIS IS EXPERIENCE TALKING HERE :oops: :oops: :oops: :oops: :oops: ---LIVELY
| All times are GMT -8. The time now is 06:32 PM. |
