-   -   Connecting rod ? (https://www.racingjunk.com/forums/showthread.php?t=19516)
jp55 01-14-2008 08:04 PM
Connecting rod ?
Who makes the best steel rod for a blown gas application making approx. 1500 hp. I'm planning a tall deck 540 w/a 4.25 stroke,6.660 rod,& a 1.395 ch piston.Thanks 8)
OneBadGMC 01-14-2008 08:10 PM
Oliver or Carillo.
jp55 01-14-2008 08:12 PM
Just checked both their websites & neither of them stock a 6.660.
jp55 01-14-2008 09:14 PM
Anyone had any experience with the Lunati Pro Mod rods or the Manley Pro Series "I" beam rods?
hammertime 01-14-2008 09:24 PM
I wouldnt buy oliver seems they like to break a lot.. Ive got pics to prove it !
Carrillo is a good rod, just make sure you get the good rod bolts and check the HP rating.
us7race 01-15-2008 02:35 AM
I think an aluminum rod would be best. They take the shock better.
bbchevy 01-15-2008 04:29 AM
Oliver
OLIVER!
They dont mind Charing for there OVER PRICED SHIT!
I have a Nice set of Billet 6.635 BBC Rods,1830.00 with the Bolt Upgrade.I sell them CHEAP!
But,heres the Deal,6 are Useable and 2 are JUNK!After 2 Passes.1 of them let go of the Bearing for an Unknown Reason?They will Sell me two more though???
Later
G :(
gimmemud 01-15-2008 05:33 AM
I use the Lunati Pro Mod Billet steel rods in a SBC with over 600hp of nos, three seasons no problems. I have never used their rods in a BBC, I always use GRP alum for BBC.
billhendren 01-15-2008 05:39 AM
Oliver makes a 6.635 rod that will easily handle that power level,we have several engines making over 2000 with that rod and no problems in 4 years . you will need to deck your block to get the correct deck height. we also use Crower billet rod for that application. H beam rods are not as good because the beam thickness doesn't give you enough side to side strength.Bill Bill
OneBadGMC 01-15-2008 07:53 AM
I banged the blower REALLY hard @ 8000 RPM on this Oliver rod. It only bent, it' didn't break. So what are you doing that's causing them to break?
http://onebadgmc.com/images/bent.jpg
