looking to build a stroker
Looking for a good recipe, to build a 600 hp small block chevy on pump gas.... any help would be great ..
No spray....
A 406ci motor should do it without much effort, 383 would also. Will this be a street motor or what ? Pump gas ?
street/strip .. was basically looking for wich rods ,pistons,crank,heads, etc Thanks for the reply..
Just built one. 406, Scat cast steel crank, Scat H-beams, Srp pistons, Pro-1 Platinumn 230's with a bit of work, mild solid roller, Super Vic, QF 950carb. 615hp and 540 ft/lbs on pump gas
Frank Advanced Performance www.get-ap.com |
Frank Advanced Performance www.get-ap.com Curtis |
Is that on pump gas ? what size bore and stroke? thanks in advance for youre help.. I see you have a website can you sell me all prts?
I had a sbc stroker built with Compstar components and I was pretty happy. It's made overseas but final machining is dome by calais.
4" stroke 4.155 bore is a good combo. compression should be no more than 10-1 for pump gas, Brodix track ones ( cnc) should make 650 hp on that setup. Al |
are you wanting to stroke it- or (de)stroke it?
like a 400 chevy crank in a 350- or a 350 crank in a 400- with a long rod ,and custom pistons? a 350 is only borable to how much? :idea: |
im guessing 12 to 1 compression!perhaps more...
| All times are GMT -8. The time now is 12:58 AM. |
