-   -   vibration (https://www.racingjunk.com/forums/showthread.php?t=19488)
taonindo 01-12-2008 10:02 AM
vibration
how much vibration can be expected from a sbc 400 with solid eng. and tranny mounts. ive been told its normal for the 400 sbc to have vibration and running solid mounts and a torque strap i can expect a lot of vibration....so how do we/i measure the amount of vibration there is? what is a lot and what is too much? any help or ideas on how to measure this would be appreciated
mytmouz 01-12-2008 10:45 AM
If you have solid engine mounts, you need to use a poly tranny mount. It'll break the tranny most likely. You're vibration problem will reduce a good bit also...
jmarksdragster 01-12-2008 06:45 PM
DO NOT EVER USE A SOLID TRANS MOUNT, especially with solid motor mounts. You will break the trans case at some point. You have no more vibration from a 400 than any other SB if it is correctly balanced. Even full tube chassis cars have some flex, most of those use front motor plates and a mid plate. A factory chassis flexes more than you can imagine and even with a roll cage and subframe connectors if needed, it will flex enough to break parts.
