-   -   yet another motor oil with high zinc content (https://www.racingjunk.com/forums/showthread.php?t=19404)
rabiddawg 01-03-2008 02:06 PM
www.bradpennracing.com
bubbabbc 01-04-2008 12:39 PM
the best oil
Brad Penn oil is highly recommended by numerous well-respected cam grinders.
tcarda 01-04-2008 01:15 PM
I started using that oil this past summer and I am extremely happy with it. Just kinda funny pouring in green oil. :D
lanham 01-04-2008 02:46 PM
lucas
I talked with Lucas Oil today about their oil stabilizer and asked if it had zinc in it and they told me no but it has other stuff in it that makes up for the zinc to help lubricate.What is everyones thoughts on this.
bubbabbc 01-05-2008 04:42 AM
Save your money and your engine. Go with the Brad Penn oil.
jmarksdragster 01-05-2008 09:25 AM
Check out this site.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
lanham 01-06-2008 02:26 PM
lucas
I don't know about Bob the oil guy and his demonstration but i have used the Lucas oil stabilizer in my semi for a few years now.I use it in the rearends,engine, transmission and mix it 50/50 with gear oil and run it in the trailer hubs.Sure i was hesitant to use it at first but when i first tried it i noticed that my oil temp ran a little cooler and that alone told me it had to help.As far as the rearends go i run 80/90 gear oil mixed with the Lucas.So one day me and a buddy was running together and his truck has synthetic gear oil in the rearends and i asked him what temp his rearends was running and mine was running the same as his with the synthetic oil.This is my experience with the product.As far as Bob the oil guy goes doesn't all oils drain back into the pan because if they don't this is news to me.
mallenwase 04-04-2019 03:32 AM
I would suggest you to use Brad Penn oil it is highly recommended by numerous well-respected cam grinders, we also have been using for a long time in a towing truck of Blocked Driveway Towing Brooklyn, and very satisfied with the performance. it will never disappoint you.
ssikolc 07-04-2023 12:23 PM
I was just checking the benefits of zinc in oil. Must say this is excellent information and I learnt why I should be putting extra zinc in my older gm or converting it to a roller cam.
annamarks 08-23-2023 08:14 AM
I started using that oil this past summer and I am extremely happy with it. Just kinda funny pouring in green oil. https://racingjunk.com/forums/images...es/biggrin.gif
